Speedo pick up >
Speedo pick up
Speedo pick up
Old 07-08-2009 | 09:29 PM
nordic95's Avatar
Default Speedo pick up
Hey guys on a 32 non stepped hull where should I mount a pick up tube for the speeedo.I have seen some mounted on the notch and some mounted on the transom.Can any one post some picks of where theirs are and let me know how accurate they are..
Thanks Anthony
nordic95 is offline
Old 07-09-2009 | 06:31 AM
I removed the stock pickup from the transom on my 27 Fever and hooked up my speedo to the built in B1 pickup.
badluck is offline
Old 07-10-2009 | 09:06 AM
nordic95's Avatar
Yea im doing just the opposite.I added nose cones to the bravo one and I dont want to drill the speedo hole thru them.So now I need to add a pick up to the transom.
Thanks Anthony
nordic95 is offline
Old 07-10-2009 | 10:14 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
No pics, but the ones I've seen are at the notch, close to the drain plug.
US1 Fountain is offline
Old 07-10-2009 | 10:32 AM
Fenderjack's Avatar
Pirate of the Chesapeake
How accurate are these type of speedo's I have heard somany mixed reviews..... ????
John
Fenderjack is offline
Old 07-10-2009 | 10:34 AM
Sorry no pic, but mine is located just right of the drain plug. it actually is between the drain and the starboard water pick-up. gud luck
poiuy10 is offline
Old 07-10-2009 | 01:08 PM
Registered User
John
Hi John,
When I went from a pitot speedo to a gps speedo I lost about 3 mph top speed, I would tend to believe that the gps is accurate and the pitot was a bit optomistic.
David
Dkahnjob is offline
Old 07-10-2009 | 06:05 PM
[QUOTE=Fenderjack;2907235]How accurate are these type of speedo's I have heard somany mixed reviews..... ????
I have a 100mph Livorsi. At 75mph GPS speed the speedo is pretty accurate (within 1 or 2 mph).
badluck is offline
Old 07-11-2009 | 08:58 AM
I got a new livorsy speedo.. tring to keep it the way it was when new..
Anyway it reads about 68 mph when the GPS say's 75. I have blown air theough the line etc.. the pick up lools like it might be bent back a litlle. I can't figure it out.
It is mounted right on the center of the transome by the drain plug
mcprodesign is offline
Old 07-11-2009 | 10:42 PM
The B1 pitot speedo pickups tend to read faster, the higher you trim the drive. You can continue to "pick up speed" on the dream meter even when you are actually losing real speed, as you trim the drive too high.
bob_t is offline
