Anyone tow with a 6.0 Suburban 2500? >
Old 07-10-2009 | 09:19 PM
Default Anyone tow with a 6.0 Suburban 2500?
And if so, how is it?
BowenCT is offline
Old 07-10-2009 | 09:20 PM
Huh, no avatar??? Looks like my membership expired..........
BowenCT is offline
Old 07-10-2009 | 09:40 PM
t500hps's Avatar
21 and 42 footers
I have an 03 with the 3.73 gears. Towed our 8,000lbs (plus fuel/trailer) 31 ft Formula fine but that was the max. When I bought our 382 I quickly needed a bigger truck.
t500hps is offline
Old 07-11-2009 | 08:59 AM
Thanks. That's about where I'm at; my 303 is about 7300 dry. I figured it'd be maxing it out.
BowenCT is offline
Old 07-12-2009 | 08:45 PM
I have an 08 2500 suburban and pull a 35 fountain. It does a nice job but getting it moving from a stop will need a lot of right foot.
I just got back from the Oshkosh Poker run and averaged 9 mpg with the air on the entire way.
bjablonski is offline
Old 07-12-2009 | 10:06 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If you are bent on an SUV, get the 2500 Suburban with the 8.1L gas engine. I've towed 12K+ with a 2500 Avalanche with the 8.1L. 12K definitely taxed the 2500 AV, but ~8500 lbs. is not a big deal at all.
Sydwayz is offline
Old 07-14-2009 | 05:35 AM
BeakBoater35's Avatar
I have the same combo...35 fountain and 2008 Suburban 2500 with 3.73 gears, 6 speed transmission. Tows fine.
My understanding is the 6 speed is noticably better than the older 5 speed.
BeakBoater35 is offline
Old 07-14-2009 | 05:56 AM
c_deezy's Avatar
The new 6.0 motor (07+) is a lot better too.
c_deezy is offline
