trs
Old 07-16-2009 | 11:14 AM
mhydro4u@aol.com's Avatar
87cafe
Default trs
anybody know this ? why is it when im flushing my starbord engine my prop spins, when i flush my port engine it does not.
IS THAT A PROBLEM.
mhydro4u@aol.com is offline
Old 07-16-2009 | 11:45 AM
what transmission?
Westcoast is offline
Old 07-16-2009 | 01:24 PM
87cafe
velvet drive, borg warner
Old 07-16-2009 | 09:12 PM
Could be adjustment of the shift linkage different between the 2.May just be the clutch plates are a little tighter in the one.Probably doesn't do it in the water. I wouldn't worry about it though.Mine tries to spin a little when I run it on the trailer.
picklenjim is offline
Old 07-16-2009 | 10:20 PM
My BW trans with a TRS will also slightly turn the prop when in neutral and flushing the engine with it on the trailer. Like stated could just be a tight clutch pack.
erik
crapr6 is offline
Old 07-17-2009 | 05:58 AM
Mbam's Avatar
Offshoreonly Advertiser
If it is a stock un-modified transmission it is usually that the forward clutch plates are starting to warp.
Mbam is offline
Old 07-17-2009 | 11:11 AM
87cafe
thank you!
