ssm V props
Old 07-17-2009 | 12:03 AM
Default ssm V props
does anyone have or know where to get 3 blade ssm V props?
- 26 spline - 17/17.5 x 31/32
thanks
magcig29 is offline
Old 07-17-2009 | 12:19 AM
thisistank's Avatar
Why would you want to run 3 blade instead of 4? Seems odd.
thisistank is online now
Old 07-17-2009 | 12:22 AM
i have a 1980 39' cigarette and its a straight bottom with #V's and about 1400 total hp and i tried one pair of 3 blade props from the era of the boat and they have worked the best so far. the 4 blades just dont seem to work as well as the 3 blades
- i have not been able to find any other sets though and would like to try some more sizes in the 3 blade but they are impossible to find
-know of anything around?
magcig29 is offline
Old 07-17-2009 | 07:55 AM
tgersx's Avatar
call randy at cobra power he has tons
tgersx is offline
Old 07-17-2009 | 08:26 AM
What size 4 blades did u try ????
A straight bottom runs nice with 4 blades if they are the right size, SSM props are very dificult to get them right,,because u have many pitch, diameter and rake props.
Also what 3 blades did u try,,,,it would help to know if u are looking for the best prop not just looking for a prop.
DareDevil is offline
Old 07-17-2009 | 09:37 AM
Mbam's Avatar
Offshoreonly Advertiser
I have a pair of 17x29 and 16 3/4 28 in 3 blade, also have some 16 1/4 x 29 5 blade.
Mbam is offline
Old 07-17-2009 | 11:28 AM
4 blades
i have tried 17x30 4 blades which were too big, 16x29 which gave me trouble getting on plane because of the small diameter,17x29 which wouldnt spin enough,
3 blades
i tried a set of 17x30 which worked very well with 0 vibration which was a nice surprise but if i could get a set of 17x31/32 i think those would work best.
- i am full stagger so i cannot go more than 17.5 diameter and it seems i cannot turn anything bigger than a 29 4 blade
do you have anything i am looking for daredevil? thanks for the help
magcig29 is offline
Old 07-17-2009 | 11:34 AM
a friend of mine has some 17X28 and 17.5X 27 but only 4 blade.
Also remember u can get them worked a little ,,,not diameter but if u thin them u get more RPM and better bite.
Also the stamped size is always off by 1.5 -2 pitches.
If it says 28 its more like a 30 the diameter is always correct.
This aplies onlyon the older Merc props the newer ones are on the money since they are CNCed.
No 3 blades.
Old 07-17-2009 | 12:20 PM
ok thank you, for 4 blades im looking for 17x26/27
anyone else have anything about 3 blades?
magcig29 is offline
Old 07-17-2009 | 12:26 PM
He also has a set of 17X27 's or 26's ,, but i think they are going to be to small for u pitch wise if u are looking for 31-32 3 blades,,,don't add up ?!
I will ask him.
