500 EFI Doesn't Like to Idle/Hard Hot Restart >
Old 07-17-2009 | 09:35 AM
Default 500 EFI Doesn't Like to Idle/Hard Hot Restart
Hey guys... I have a pair of 2001 500 EFIs with Boostpower induction package on them (tb's, filters, spacers, computers, etc). Motors have roughly 150 hours on them. Port motor is a champ, runs perfect, idles forever. Starboard motor likes to cut out at idle occasionaly and can be difficult to restart warm. If I cut the motors off to talk to someone it can take a few minutes of cranking for it to fire. Above idle they both run like champs, don't miss a beat and run identical on instrumentation. Any ideas? No alarms or horns. I'm betting it's some sensor, IAC, TPS, or something simple.
Jpzaluski is offline
Old 07-17-2009 | 12:17 PM
rush's Avatar
I would think IAC, sometimes you can take it out and clean it with carb cleaner. it screws out.
rush is offline
Old 07-17-2009 | 09:09 PM
Pwrbt33's Avatar
I was thinking IAC valve as well, Have you tried to move the throttle forward when cranking to see if that helped it start any easier?
Pwrbt33 is offline
Old 07-22-2009 | 06:26 AM
swap out the iac with the other engine,,to check it
TWIN-SPINS is offline
Old 07-13-2013 | 11:55 AM
What did you find on this? I'm having the same issues.
cbrand2310 is offline
Old 07-13-2013 | 12:51 PM
Sounds like vapor lock.
Griff is offline
Old 07-13-2013 | 04:37 PM
t500hps's Avatar
21 and 42 footers
If it were the port motor on a pre-2002 500efi I'd swear it was vapor lock.....the starboard can still have that issue but the port fuel pump bwing sandwiched between the 2 engines is usually what causes vapor lock (obviously worse when hot out)
t500hps is offline
Old 07-27-2013 | 08:08 AM
Mine is the starboard.
