Bravo, IMCO, XR parts >
Old 07-22-2009 | 02:35 AM
LAKE EFFECT's Avatar
Default Bravo, IMCO, XR parts
I recently upgraded my drives to all XR parts, and have some parts that need to go. I will get some pictures asap, all prices plus shipping and best offer.
Scott 216-214-2462 [email protected]
1 pair early Imco Extreme upper units: 1.36(29/27)gears w/welded floors, Imco modified upper caps, Imco lower towers, w/L-15 u joints(no input yokes), no pitting on gears. Imco sets these units up with a right and left rotation. $2000.00 for the pair
2 std Bravo lower unit housings: nose cones, water holes are welded closed, clean housings but need paint, water holes can be re-drilled, I bought these with my XR uppers and never used them. $300 ea.
2 drive showers w/hoses and hardware: 1 is stamped Imco, 1 looks identical. $50 ea.
2 std Bravo lower vertical shafts: $100 ea.
1 std Bravo 1" prop shaft: .003 runout. $150
2 std Bravo 1" prop shaft carriers: w/seals $75 ea.
2 sets Bravo lower gears(non XR): 15/19, 1 set pitted on left rotation, but new on rt rotation. $100. 2nd set slight wear pattern(rt rotation) new on left rotation $150.
2 XR input u-joint yoke shafts: engine coupler to u-joint, GKN style u-joint. $125 ea.
1 Imco ext box input shaft: engine coupler to u-joint, torsional shaft, L-15 u-joint. $150
2 XR prop shafts: Mercury, less then .002 runout . $450 ea.
2 XR prop shaft bearing carriers: Mercury, w/seals. $275 ea.
2 sets XR lower gears: 15/19, both sets are pitted on one side and good on opposite side(5 hrs). $100 ea.
http://s734.photobucket.com/albums/w...afilter=images
LE
LAKE EFFECT is offline
Old 07-22-2009 | 02:41 AM
The IMCO drives are painted with black imron. I put my Max machine and Latham caps on my new drives. I have painted the caps that come with the drives and they look alot better now.
LE
Old 07-24-2009 | 04:28 AM
bump..
Old 07-24-2009 | 11:02 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Default drives
Do you have any pic's of the uppers. Thanks JOHN
Fenderjack is offline
Old 07-28-2009 | 11:44 AM
ttt
Old 07-28-2009 | 05:48 PM
i would like to change my 1.36 ratio drive to a 1.50 do you have what i need. Bravo 1
Fixxxer22 is offline
Old 07-28-2009 | 09:25 PM
LE
I broke my propshaft last weekend and need a new one, part# 44-41630, i think thats the one u have, wahat does that .003 runout represent, is that wear or side to side movement when assembled, u have any props for sale?
SAMDAHL76 is offline
Old 07-30-2009 | 10:06 AM
Merc specs state you replace if over .005 runout in the shaft. To compare, when I bought new XR shafts I saw .0015/.002 runout. I was just stating it is good straight shaft.
LE
Old 07-30-2009 | 10:08 AM
Sorry, these drives will only get you a 1.36 ratio.
LE
Old 07-30-2009 | 10:33 AM
Lowered some prices.
1 pair early Imco Extreme upper units: 1.36(29/27)gears w/welded floors, Imco modified upper caps, Imco lower towers, w/L-15 u joints(no input yokes), no pitting on gears. Imco sets these units up with a right and left rotation. 1650.00 for the pair
2 std Bravo lower unit housings: nose cones, water holes are welded closed, clean housings but need paint, water holes can be re-drilled, I bought these with my XR uppers and never used them. $200 ea.
2 XR input u-joint yoke shafts: engine coupler to u-joint, GKN style u-joint. $100 ea.
2 XR prop shafts: Mercury, less then .002 runout . $400 ea.
2 XR prop shaft bearing carriers: Mercury, w/seals. $225 ea.
Lowered some prices..
