outdrive knocking at idle in gear? >
Old 07-24-2009 | 09:10 PM
Default outdrive knocking at idle in gear?
Just put boat in water tonight and the outdrive is knocking in gear. I am thinking u-joint. Any one with experience here? It doesn't seem to get any louder when I throttle up and get on plane I can't here it. Exhaust is loud though. Will it last the day tommorrow if I take it easy?
Justin
jlowe is offline
Old 07-24-2009 | 09:34 PM
Justin
I think if u hear knocking noise it will not last ,,and if its the u-joint u can sink the boat if it rupteres the bellow !!!!!
So if i where u ,,i take it back out and put it on the trailer and check it !!!!!!!!!!!!!!!!!!!!!!!
DareDevil is offline
Old 07-25-2009 | 06:36 AM
does that sound like a u-joint symptom?
jlowe is offline
Old 07-25-2009 | 07:34 AM
Could be U joint, typically they change noise or amount they make when you turn/trim etc. If it is constant thru steerage and trimming up etc. I would say something else going on. But I dunno if I would take boat out with it knocking, at the least least gonna tear more stuff up.
happy hours is offline
Old 07-25-2009 | 07:55 AM
GO4BROKE's Avatar
My bravo knocked at idle, it lasted about 30 mins before it blew.
[img][/img]
GO4BROKE is offline
Old 07-29-2009 | 05:20 PM
Well I figured out the knocking in the outdrive.
two teeth chewed off the forward gear. Guess the new motor wass definately too much for a Bravo. Gonna get a new custom built Xr from Eddie Young. Hope that one holds up.
Justin
jlowe is offline
