trim sender limit switch
you have to buy the kit, i just switched out both due to perished insulation. however if the wire is good you can cut and splice the new one in with shrink and seal heat shrink
I did that on my buddy's 204 Eliminator edge. The wires are good adn so are the bodies ofthe senders just the ceramic with the contact patches on it is worn off. Does anyone know where i can get just the ceramics with the hex plug?
Thanx in advance
Thanx in advance
These guys are right. I looked them up on www.mercruiserparts.com
look for a product called liquid tape, you can make any electrical connection completely waterproof. That is how we secure all aftermarket connections on our atv's. And we spend a lot of time in 3' or more of water. Works great on boat connections also.
