Service 4wd message
Old 08-03-2009 | 01:33 PM
JLAY's Avatar
Default Service 4wd message
On my 04 chevy Z71 i sometimes get a service 4wd message on my gauge cluster. When I read the owners manual it says to pull over and turn the truck off, turn it back on and if the message is still there, bring it in for service? What kind of service does it need. The truck only has about 75000 miles. Can anyone tell me what is triggering the message to come on? Thanks in advance!
JLAY is offline
Old 08-03-2009 | 01:55 PM
Strip Poker 388's Avatar
Rob
My 2003 does it, its been in the shop reprogramed,also I remember something about a recall on the switch panel,also the first time the plug on the 4x4 switch wasn't pluged in good,So as far as me I dont think they have a fix for it,im going on 3 years since i got them to reprogram it,still dose it,
They had a reprogram on the seat memory also.
Rob
Strip Poker 388 is offline
Old 08-03-2009 | 07:02 PM
Quinlan's Avatar
Mine has been doing that too. 07classic. Dealer said something about switch panel too. I just hit the milage odom reset now and it goes off.
Sure would be nice to know what the heck causes it.
Quinlan is offline
Old 08-03-2009 | 08:08 PM
Does 4WD work normally when message is not displayed? Codes will be set when displayed-dealer should be able to scan and retrieve
formula racer is offline
Old 08-04-2009 | 08:19 AM
JLAY's Avatar
Thanks Rob, I will make sure it is plugged in. The 4wd works fine, I don't use it that often, I don't go mud-riding or anything out of the ordinary. I thought it may be a message telling me to change the oil in the transfer case. Rob is your boat going to be ready for the g.c. offshore patroit poker run? Thanks guys for all the input!
JLAY is offline
Old 08-04-2009 | 02:48 PM
waterbum's Avatar
I have an '04 Silverado 4X4. That light has come on twice and would not go off. Took it to the dealer and both times they said it was a false message. They replaced some switch / circuit behind the panel. First time it was under warranty. Second time cost me about $150. Mine has around 40K miles.
waterbum is offline
Old 08-05-2009 | 12:40 PM
Most of the time it is a sensor or switch malfunction, goes away. If it stays on for several days then it may need to be fixed. There is an easy fix go to webites that handle GM vehichles and do a search.
Wannabe
wannabe is offline
Old 08-06-2009 | 12:12 AM
Rob
Thanks Rob, I will make sure it is plugged in. The 4wd works fine, I don't use it that often, I don't go mud-riding or anything out of the ordinary. I thought it may be a message telling me to change the oil in the transfer case. Rob is your boat going to be ready for the g.c. offshore patriot poker run? Thanks guys for all the input!
They told me its a common prob, my trans works fine,my boat doesn't like being towed in stage 3 on the edge.you all with the newer models will have more power than mine.theres a reprogram on the 4x4 ,really didn't make a diff, it still pops up, if ya change the digital read out to something else, it goes away, rumor, a sensor on the trans might cause it?? rumor.. Ive got 90k and hadn't change transfer case, I was thinking the trans fluid is the same???
My boat will not be ready, still in paint ,new excuse he broke his wrist, its been since Dec 15th,I'm FKED,he just want finish it, he never runs out of excuses.He will regret it the rest of his life one way or another!!!
the pluggy thingy, the ac/heater panel needed replugging in also, again this is a 2003,
Old 08-06-2009 | 10:17 PM
JLAY's Avatar
Thanks for all the input guys!!!
JLAY is offline
Old 08-06-2009 | 11:32 PM
HiPerf2000's Avatar
switch panel. common problem.
HiPerf2000 is offline
