Plumbing oil cooler and remote >
Old 08-05-2009 | 08:57 PM
Default Plumbing oil cooler and remote
Finally ready to install new oil lines on fresh rebuilds. I was thinking of running lines from filter adapter, to oil cooler, to filter remote, back to block. Is this correct, or should I go to filter, cooler, back to block?
Thanks for any suggestions, BC
Cold Sweat is offline
Old 08-05-2009 | 09:22 PM
Out of the block to the filter, then to the cooler, then back to block. Atleast this is how I do it.
niceguy is offline
Old 08-05-2009 | 09:27 PM
I would agree and about to be doing the same thing on my new installs. filtering the oil prior to the cooler would make good sense.
getrdunn is offline
Old 08-05-2009 | 09:30 PM
Yep
DareDevil is offline
Old 08-05-2009 | 10:00 PM
Default filter diagram
check out Hardin Marine's website, www.hardin-marine.com access their tech support tab. there is all types of useful info. scroll down to oil filters, and click on thermofilter. there you will see a cut-a-way illustration with the flow direction of how you should plumb your lines. I also would suggest that the oil flow at the cooler run against the flow of the cooling water.
smokinbob is offline
Old 08-06-2009 | 02:20 AM
Probably a simple answer to this question i just haven't thought of yet but, Why?
Also, my thoughts are I'd want the oil filter after the cooler in case the cooler drops something into the oil. Is it better for the filter to get the oil while it's still hot so it lowers the flow pressure on the filter or something? I run the big K&N 3002 filter, is it an issue?
I'd really love to hear about that reverse flow thingy though.
Cheers,
John
Ghostrider is offline
Old 08-06-2009 | 08:58 AM
c_deezy's Avatar
The main reason for the filter before the cooler is to try to keep from contaminating the cooler in the case of engine destruction or even normal engine wear particles building up. And it no doubt helps to have hot oil going through the filter instead of 'cooled' oil.
c_deezy is offline
Old 08-06-2009 | 09:59 PM
Default oil cooling
Cheers,
John
the reason for running the hot oil against the direction of the cooling water is optimum heat transfer. the oil is being cooled by the coldest charge possible.
