Go Back  Offshoreonly.com > Owners Forum > Powerquest
depth sounder >
depth sounder
depth sounder
Old 08-09-2009 | 06:46 PM
Default depth sounder
I have a 2000 PQ290 Enticer and my lowrance 3500 depth sounder no longer works. My question is can I mount a puck style transducer to the bottom of the bilge or will it need to be drilled in. Is it just a solid fiberglass hull with no core? Thanks for any help you can give me.
falconhunter is offline
Old 08-10-2009 | 08:22 AM
you have a balsa core hull.
boatnt is offline
Old 08-10-2009 | 03:55 PM
Thanks boatnt
Old 08-10-2009 | 04:24 PM
Does that mean a transducer won't work right if glued in the bilge compartment? If so, that explains why mine doesn't work once I start moving............
AngerMgmt is offline
Old 08-11-2009 | 05:19 AM
hp500efi's Avatar
Member #9
FalconHunter, welcome to the site
where are you from, where do you boat?
the 290's are great boats.
Member of the Liquid Jungle
hp500efi is offline
Old 08-12-2009 | 07:48 AM
dockrocker's Avatar
boatnt, how do you like the 300 vs the 290?
dockrocker is offline
Old 08-12-2009 | 02:55 PM
Elite Marine's Avatar
Drill it out to the outer layer to install the transudcer. Dont forget the mineral oil!!
Elite Marine is offline
Old 08-12-2009 | 06:51 PM
Thanks for the welcome. I am in Texas and primarily boat on lake Conroe. So far the 290 has been very stable and reliable.
