When to add Stud Girdles???
Call it a rookie question or a point for conversation, but when do you actually NEED to add a stud gridle kit?
I've been told they're good to have if you run a solid lift / solid roller set up with heavy springs or high seat pressures which may flex the studs, but is there a general rule at which point you'd actually need them?
I'm just curious, I run Hyd roller so I doubt I'd ever need them but I'd like to know what all the fuss is about.
I can understand the Small Block crowd running them because they ring the neck out of their engines at 7500rpm and things flexing at that speed just aren't cool.
But on a BBC? When do you need them?
I don't use them. When I get to the point that I need something better than a stud mounted rocker, I go to shaft mounted rockers(Jesel). By the time you factor in rocker arms, guide plates, studs, girdle, poly locks, etc, you are only about $150-$200 short of buying Jesels. It is just worth it in my opinion. Some of the engines that I use them on don't require them, people just expect it at that price and power level. Most of my engines make their peak power at 5400-5500 rpms. If I am going to turn one much over that, I will use the shaft mounted rockers. It just becomes a factor of rpm and spring pressure. Hope this helps, Eddie.
