Question On Thru Hull Depth Finder On 29 >
Old 08-16-2009 | 12:30 AM
Default Question On Thru Hull Depth Finder On 29
Looking at a 29 outlaw,has a black plug in bottom between the motors. All I could figure is that its a depth finder, has a small round box on top with a wire coming out. Just not familiar with a thru hull design. Anyone use these and any problems to look for. THANKS JOHN B
1fast432 is offline
Old 08-16-2009 | 08:32 AM
I have an "IN" hull, that may be what you are referring to. There are THRU hull, but they seem to be less common.
You can figure that out by looking under the boat, you see anything? If not, it's an IN hull. Nothing to worry about. I think it is the best way to read depth. I much prefer it to transom mount transducers.
PJDiesel is offline
Old 08-16-2009 | 09:06 AM
The plug is on the bottom of the boat with the round box and wire inside the boat. THANKS
1fast432 is offline
Old 08-16-2009 | 09:39 AM
Thru then.
No biggie. As long as it was sealed up properly (like any below the water line through fitting) it should be fine.
Usually people use 5200 or similar. For the most part you had better MEAN it when you apply 5200, .........it's there to stay.
PJDiesel is offline
Old 08-16-2009 | 07:16 PM
RICHARD CUNY's Avatar
I Installed A Liversie Unit In Hull Mounts Inside They Recomend Epoxy Mine Works Great Speeds Up To 75 Mph
Rich
WATCHUS
RICHARD CUNY is offline
