Does anyone know what distributer gear to use on a HP500 Camshaft >
Old 08-16-2009 | 04:18 PM
Default Does anyone know what distributer gear to use on a HP500 Camshaft
I recently put together a 496 chevy and used a matched set of roller lifters and cam out of a hp 500 my question is can i use the stock distributer gear off my 454 mag distributer , or do i need a brass one the cam i put in is suppose to be a steel cam not sure what to do ??
stingray698 is offline
Old 08-16-2009 | 05:51 PM
Pwrbt33's Avatar
Use your stock gear that was on your 454 distributor. Do not use the bronze gear.
Pwrbt33 is offline
Old 08-16-2009 | 07:46 PM
ok well i was looking closely at the gear today and the teeth are worn so do I put a new iron gear on?
Old 08-16-2009 | 07:58 PM
Just use a standard cast steel gear. The cam gear is made for it.
Griff is offline
