Whipple vs. Magnacharger >
Old 08-16-2009 | 06:56 PM
Default Whipple vs. Magnacharger
Well I'm scrapping the idea of swapping my 350 for a 496... Its just going to cost to much. So supercharging the 350 is the way I'm going! My question is which is better and why. A Magnacharger or a Whipple. I know most everyone is using Whipples. I'm just curious why nobody talks about the Magnacharger. FYI this is going on an '87 350 magnum.
endeavour32 is offline
Old 08-16-2009 | 08:01 PM
I would just use a small roots blower like a Wieand 177 or B&M 174.
Griff is offline
Old 08-16-2009 | 08:17 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Procharger....
John jr
Fenderjack is offline
Old 08-17-2009 | 08:03 AM
If you think it will cost to much for a 496 you really do not want to start playing with a blower of any kind .
Jeff P31 is offline
Old 08-17-2009 | 10:13 AM
CB-BLR's Avatar
Chris
Innercooled Whipple is the only way to go. Had them all, and this is by far the best setup.
Just my experienced opinion.
Chris
CB-BLR is offline
Old 08-17-2009 | 10:52 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
What compression ratio is your motor? I thought 350 mags are 9.5 in the late 80's
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 08-17-2009 | 07:22 PM
To be honest I'm not sure what the Mag is.... I'm pretty sure it's 9.0 to 1 but I could be wrong on this.
Old 08-17-2009 | 07:30 PM
Jeff,
In order to get my 496 block converted for marine use it would cost over $6000 in all the little parts. It's very hard to find anything for this motor and when you do it's big bucks!!!!!! Raylar heads for example are somewhere around $3500.00 and there only good for 50 hp. I can get AFR heads for my small block and there good for 80+ hp and only cost $1500. So if I put $6000 in the small block I would have one wicked motor with far more power than a stock 496 ho.
a really good set of heads and a cam will put you at the power level a 9.1 blower will make for 1/2 the $$$ and twice the reliability.
fastdonzi is offline
Old 08-17-2009 | 08:03 PM
X2
Dude.. I been here....
Youll be dicking with this till the end of time if you bolt a blower on a stock small block. I chased blown small blocks around for years - unless you are going to do a complete teardown and rebuild stay away from blowers of any kind.
Spend your money like this.
Exhaust (without spending the money on this your pi$$ing up a rope)
AFR/Brodix heads/intake combo
good "relatively" mild roller cam setup
Go boating.
There are NO shortcuts in engine building. I know you wanted to hear it would be ok to bolt a blower on- its not, and the blower sales guys will rarely level with you about this.
UD
Uncle Dave is offline
