Prop Lost And Found
Old 08-17-2009 | 09:02 AM
KNOT-RIGHT's Avatar
Default Prop Lost And Found
Can anyone help a brother out?
We lost a prop out on Narragansett Bay.
The Mcloud Prop lock backed right off.
This is the second incident with these locks please be advise.
Anyone have any leads on one right hand 37.5P 5 blade Herring?
Please call Gerry
Thanks in Advance
508-399-6440
KNOT-RIGHT is offline
Old 08-17-2009 | 09:18 AM
seafordguy's Avatar
I would cry if I lost a Herring.....
seafordguy is offline
Old 08-17-2009 | 12:11 PM
KNOT-RIGHT's Avatar
I did for a little while
I called Randy at Cobra he may have one lined up.
Old 08-17-2009 | 12:19 PM
animalhouse's Avatar
We might have one, what is the pitch? 17 1/2 x ??
animalhouse is offline
Old 08-17-2009 | 02:46 PM
KNOT-RIGHT's Avatar
It was a 16 .5 Herring 37.5 five blade RH.
I can have anything close worked on.
Thanks Fred
Paul drove right by the Borden Light Marina Saturday.
Thought he was going to join us.
Old 08-17-2009 | 02:50 PM
He went to Long Island, Mike saw the guys running in and ran with a few of them for a while, we would have loved to do the run, but had a scheduling problem with some customers coming in.
I will give you a call after I check out the stock room.
Old 08-17-2009 | 03:39 PM
KNOT-RIGHT's Avatar
This is one of the Perks of having a HiGHLINE Boat builder
in your backyard.
Thanks Fred!
Old 08-18-2009 | 08:22 AM
KNOT-RIGHT's Avatar
Anyone ever drill the very end of the 6 Shaft and install a cotter pin?
HEY JC PERFORMANCE any of you long Island boys got any
Props laying around???????
Old 08-18-2009 | 08:25 AM
Audiofn's Avatar
Charter Member #232
Woudl probably just shear off the cotter pin once the nut loosened up. What about double nutting?
Put your best foot forward!
Audiofn is offline
Old 08-18-2009 | 12:50 PM
KNOT-RIGHT's Avatar
Whaz up Jon?
Yes Good suggestion What I may try is use factory nut.
Then back down the locks to that.
Pete Nopper just got off the phone with Mercury HP
They require 100ftlbs.
The problem with the 6 locks is once you continue to reuse
them the Key does not grab it properly allowing the proper torque.
This is what cost me the prop
