What works best to remove ring around around boat from river >
Old 08-17-2009 | 05:43 PM
Default What works best to remove ring around around boat from river
What works the best to remove yellow ring aroundthe wTerline on my boat fromthe Ohio river? I got most all of it off but still a hint of yellow in some places.... Boat is white....
jmoore1225 is offline
Old 08-17-2009 | 05:49 PM
The WORKS bowl cleaner from the local grocery store ,squirt it on & hose it off ...
Old 08-17-2009 | 05:50 PM
on off cleaner, kills everything or paracid hd i think it is, or oxcalic acid, not sure on spelling of last, check to make sure they are fine for paint if your boat is painted, and do not get them on plastics
Timeless61 is offline
Old 08-17-2009 | 05:55 PM
I boat on the upper Ohio Slimy Grimey mix it with water and use a sprayer I use a garden sprayer it is the best, I use everytime I pull out acid (toliet bowl cleaner and muric acid) will eat trailer paint.
Sweet Nmocean is offline
Old 08-17-2009 | 07:47 PM
After you get it off using those recommendations above, wax it with Collinite Heavy Duty Paste Fleet Wax No. 885. I started using it this year (4th year boating on the Mississippi River) and it is the best I have used yet. Lasts by far the longest and really helps prevent staining.
4mulafastech is offline
Audiofn's Avatar
Charter Member #232
If you use ON/OFF make sure you do not have an galvanized trailer!
Put your best foot forward!
Audiofn is offline
Old 08-17-2009 | 07:50 PM
bcfountain's Avatar
Registered User
Default on-off
on-off is about the best i have found.i get the same crap on my fountain.only thing about the on-off.you must wax the area you clean,and the more you use the cleaner the more you have to clean/wax.hope this helps.
bcfountain is offline
Old 08-17-2009 | 09:46 PM
MarkSmith's Avatar
Sno-bowl toilet bowl cleaner.
MarkSmith is offline
Old 08-17-2009 | 09:56 PM
ON/OFF Best!
PARADISE ISLAND is offline
Old 08-17-2009 | 10:06 PM
I 2nd Sno-Bowl then a good wax and buff. Just be ready for the acid sting if it gets on ya, keep the water running!
ckin62 is offline
