Mercruiser scan tool
Old 04-03-2002 | 11:26 AM
SeaDated's Avatar
Default Mercruiser scan tool
Help help, where is the best place to get a scan tool?
SeaDated is offline
Old 04-03-2002 | 11:58 AM
Jan's Avatar
Jan
Member "69" Charter #70
Here is the company that makes them, not sure if you can buy direct.
http://216.230.203.183/marine/mtspec.htm
Jan
Jan is offline
Old 04-03-2002 | 04:50 PM
Revelocity's Avatar
Rinda Technologies oem's some scanners for Mercury and will sell direct.
www.rinda.com
Revelocity is offline
Old 04-03-2002 | 05:34 PM
Dreamweaver
SeaDated - I might be able to get this for you... I'll check.
Old 04-04-2002 | 12:01 AM
SteveDavid's Avatar
Charter Member #1093
SeaDated,
You're welcome to borrow mine. It's the older version, works fine on 500 EFI's, etc. There is a newer version with changeable cartridges for various installations and I believe even more data capture.
Mine displays about every variable the ECU processes. I can send it to you after the 15th. if that's not too late for you. (Dustin is in town the 14th. and we'll need it for various tests that weekend, after that you're free to use it as long as you like.)
Steve
SteveDavid is offline
Old 04-21-2002 | 01:28 PM
28Eliminator's Avatar
It looks like the DIACOM PLUS software is the hot ticket if you have a laptop computer. You could hook it up and monitor problems while cruising in the boat, when you have an ntermittent
problem that only occurs under load.
A question? It looks like these only monitor the status of the computer and sensors. So how do these builders and aftermarket HP guys reprogram the computer?
1. Do they just use special software on a computer and a special
interface cable like newer cars.
2. Do they program a chip and replace it like older cars. I think not
Mmmmm, I'm sure a lot of people on the board are wondering the same thing. Inquiring minds want to know.
28Eliminator is offline
Old 05-14-2003 | 12:16 PM
Smitty's Avatar
I called Rinda and they quoted me 399.00 plus tax.
Smitty is offline
Old 05-14-2003 | 01:29 PM
C_Spray's Avatar
Diamond Member #001
Default I was thinking (I know...I know...)
After struggling with a notoriously unreliable fuel gauge for several seasons, I've been thinking about installing fuel flow meters/totalizers in my boat. The problem is that the "over 500 hp" FloScan units are expensive. Since my boat uses GM EFI, wouldn't a scan tool like this give me what I am looking for (and then some) at far less $$$? Just need to figure out how to mount a couple of them on the dash without it looking too unsightly....
C_Spray is offline
Harper220
12
12-05-2019 07:48 PM
QWKRN U
Wanted
4
10-13-2008 08:00 PM
Boatfixr
01-29-2008 11:48 PM
DORaymond
6
09-05-2007 08:19 PM
CcanDo
03-06-2007 10:58 PM
