What coolant for 496HO? >
Old 08-20-2009 | 04:15 PM
Default What coolant for 496HO?
Hi, do you know what coolant to use for a 496HO.
From what I've read it takes pure coolant, no water mix so wondered what spec coolant it can take, and what type is normally in it?
Richard
richard is offline
Old 08-20-2009 | 04:55 PM
Use the red dex- cool, you can mix it with water... Hope that helps
DOUBLE OR NOTHIN is offline
Old 08-21-2009 | 01:04 AM
Richard
I believe the pure coolant you read about was the Merc branded dex cool. It comes pre-diluted with water so you don't add additional water to that product.
Remember, pure anitfreeze will freeze when cold. If you use standard dex cool (not merc) then mix it with water about 50/50 or 60/40. If you live where it gets much below 30 degrees, just use merc or find out what the manual calls for on the mix ratio.
SDFever is offline
Old 08-21-2009 | 07:29 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
If you want the best stuff, drain it all out, flush it & run Shell or Cat ELC style coolant.. It's a bit more $$ but a lot better stuff.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
