disc brakes [ need help ]
On my trailer I was able to order and replace the whole tounge assembly with the correct master cylinder already in place. All I had to do was remove three bolts and the brake hose. Reassemble and bleed.
Depends on your coupler, but probably, here is a link that has alot of tech help. should answer alot of questions. http://www.championtrailers.com/techsup.html
