28 thunder set ups >
28 thunder set ups
28 thunder set ups
Old 08-26-2009 | 06:26 PM
Default 28 thunder set ups
any 28 thunder owners with 500efi what prop are you running at what gps speed and rpm,, been trying all summer to get my buddys 28 dialed in. works best with a left handed 24 4 blade it hit 69 on gps at 5200, im thinking he should be able to spin a 26 labbed. he has a 26 labbed that spins 5000 and only low 60 mph i think it has a bad slippage problem.
thanks
rssteiny is offline
Old 08-26-2009 | 09:18 PM
outriggers's Avatar
I think the year makes a differance on the 28's. Maybe Pat will chime in. Doug
outriggers is offline
Old 08-26-2009 | 09:41 PM
Gladhe8er's Avatar
Not sure if it will help, but my 525 boat spins a 26 BBlades labbed 4 blade bravo at 5200 RPM and about 73 MPH.
Gladhe8er is offline
Old 08-26-2009 | 09:59 PM
http://go-fast.com/Prop_Slip_Calculator.htm
try this prop slip calculator, it should cut out a lot of guess work
My Addiction is offline
Old 08-27-2009 | 06:48 AM
This is a 2002, based on the 525 boat spinning a 26 at 5200 and 73 the 500efi may only spin a 24 at 5200 and 69-70 sounds about right.
rssteiny is offline
Old 08-27-2009 | 07:11 AM
slboatdrinks's Avatar
Rick,
You have the right prop on that 28.
Steve
slboatdrinks is offline
Old 08-27-2009 | 04:21 PM
Rick,
Steve
What the 24 or the 26 ??
rssteiny is offline
Old 08-27-2009 | 05:02 PM
ActiveThunder's Avatar
Stock RH 26 Bravo on 2004 or newer 28 with a 525 runs 73-75.
Stock LH 24 Bravo on the 2002 back 28 with a 500 runs 69-71.
Lab finished Merc prop up two pitches and gain 2-3.
Full time mufflers, scrub 5. (don't ask)
ActiveThunder is offline
Old 08-27-2009 | 05:11 PM
24 LH.
Or just look at Pat's post.
Old 08-27-2009 | 05:20 PM
Originally Posted by OCDACTIVE
How about a 1999? with a 500?
And I have to be that guy............. Gibson Clamp on Mufflers.. They swore there would be no performance loss.... Did I get Fanageled??
Your answer is in his post:
Stock LH 24 Bravo on the 2002 and back 28, with a 500 runs 69-71.
