89 4.3 omc cobra wont start
i have an 89 4.3 omc cobra, i had it running in the driveway for 30 min shut it off and took it to the delta at the beginning of the year. when i put it in it wouldn't start and hasnt since. it gets fuel, good spark and cranks fine. please help
how are you checking for fuel? look in the carb and watch if the accellerator pump is pumping fuel in, you need 3 things to run, spark (at the right time), fuel and compression, if you have fuel in the intake and it will not start or try to start, I would look to the ignition sys. spark could be to weak fire the plugs, thats got the old points and condensor sys. with a spark tester check the coil for a good strong spark, blue in color, points and condensor are cheap replace them.
let us know how it comes out.
larry
larry
is the fuel good?,,,,,,, pour a capful of lawnmower gas down the carb,,,, put the flame arrestor back on and try that.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Will it crank over or will it not crank over at all? With you checking the obviuos I'm getting it will crank but won't start. Does it have electronic ignition or separate coil? I have seen where the distributer takes a crap. If you have good fuel I would check to make sure everything is grounded properly.
Let us know what it ends up being.
