f250 lowering kit????
Old 09-07-2009 | 03:06 PM
fastlane40's Avatar
Default f250 lowering kit????
I've got a 06 f250 crew cab(4 big doors)7.3 4wd i want to lower.It has leaf springs front and rear.Does anybody know if there's a kit available?Thanks
fastlane40 is offline
Old 09-07-2009 | 05:45 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
A 2006 with the 7.3L? They stopped putting the 7.3L PSD in the Superduty in 2003. I'm not sure if its different in Australia vs. North America.
Sydwayz is offline
Old 09-08-2009 | 07:43 AM
fastlane40's Avatar
Must be.I've got a 2006 with the steering wheel on the right hand side.
Old 09-08-2009 | 09:53 AM
in 05 ford went to a coil spring front end in the us. if you can get a part # off the leaf spring we could tell if the 04 and down design would work,or if its something completely different.
gofastkyle is offline
Old 09-08-2009 | 02:45 PM
fastlane40's Avatar
Okay i'll see what i can find.The f series was stopped here in 2006.Still popular and you won't believe the prices.
Search "carpoint" in Australia to check them out.
Old 09-08-2009 | 04:47 PM
LapseofReason's Avatar
Put 05 USA spec. Excursion springs in the front and the block in the rear. Be about 2 inches lower.
LapseofReason is offline
Old 09-08-2009 | 04:49 PM
Did you ever get the 6.0 POS motor over there ?
Old 09-08-2009 | 06:52 PM
ford used 2 different blocks, a 2 ", and a 3 1/2". you probably have the 2". remove the factory block and rest the springs right on the axle. new u-bolts will need to be used. if your going to tow airbags would be a good idea. the excursion front springs should lower the truck. new shocks all the way around wouldnt hurt either.
Old 09-13-2009 | 07:13 PM
I would love to lower my 04 f250 4x4, it is to tall for my garage. I think 2 inches would let it in.
Sweet Nmocean is offline
Old 09-14-2009 | 04:57 AM
fastlane40's Avatar
No we never got the 6 liter here.They last came into the country in 06 with the 7.3.They are so popular though.
Get on Carpoint in Australia and search f250.You will be shocked at the prices.
Hard to get Excursion springs over here.They were never released.
