bravo 1 stuck in forward
went out for a ride this am, everything worked fine boat ran great..when we came back to ramp, pulled back on the lever, felt no drag and stays in forward, checked lever on transom cables working fine and all are new, any idea's ?? could cable end popped off at the drive ? thanks Rob
Rob,
Drain the lube down some and pull the back cap.. you may have lost a bolt in the shift lever, but you will be able to see if the cable is connected to the shift linkage by watching the cam on the shift fork rotate. If it doesnt move, either the cable is no longer attached (pull the drive) or the shift shaft is turning, but the cam is not..
Hope this helps..
Dick
Hope this helps..
Dick
Under the cover you will see the shift linkage in the bottom opening and the shift fork/cam in the upper opening. There is a bolt in the cam and one in the linkage that holds it to the shift rod..
Hey Ezstriper,I had the same thing happen to me last Week.The end of my cable where the lead end is pulled out of the latch mechanism.I pulled the drive and replaced the latch($5.00)and it works great.I had bunch of guys saying my cone was stuck in forward and that stuff but it was just a bad latch.Shifts and works great.Good luck.
