Full Force carnage......
Old 09-08-2009 | 01:59 PM
Full Force's Avatar
Default Full Force carnage......
She broke good this time...... hole in piston, broken valve....no cracked head, no cracked block, thats good... should not be too big of a deal to fix, I have all winter..pics are nasty!! Valve stem punctured piston, thats where my water in oil came from...
Full Force is offline
Old 09-08-2009 | 02:06 PM
Wobble's Avatar
SORE MEMBER
I have seen that before, it appears you got off lightly.
My buddies engine dropped the valve due to a bad guide. the base traveled through the intake and wrecked another piston ,head, broke the rod and screwed the block.
Wobble is offline
Old 09-08-2009 | 02:30 PM
Full Force's Avatar
Yea, I really think this is best case... just need a piston and refresh, and valves of course..
Old 09-08-2009 | 03:04 PM
You did get offf lightly. Usually, pieces of the piston will cross over the intake and trash the other side as well. I have seen then open a cylinder up like a sardine can. Give me a shout if I can help. Good luck, Eddie.
Young Performance is offline
Old 09-08-2009 | 03:57 PM
Looks familiar..... happened a few weekends ago in the 598. A piece of the valve traveled over to the other side and damaged the opposing piston as well. Doesnt look like the block is damaged at all, which is really suprising. Something stuck the intake valve open though, and busted the retainer.
Philm is offline
Old 09-08-2009 | 04:13 PM
Yep....been there...not as lucky as you. I lost a chuck of the block and the head.
Scarab Billy is offline
Old 09-08-2009 | 06:35 PM
Racegirl3's Avatar
Easily Distracted
Sorry to hear you had issues
Bad Girls Make Good Company
Racegirl3 is offline
Old 09-08-2009 | 06:44 PM
Rookie's Avatar
Been there, done that. Just like me you got lucky. My head cracked the between the exhaust and intake seats. Dropped the exhaust seat and exhaust valve took out piston. I caught mine in seconds. I only had to hone my cylinder.
Rookie is offline
Old 09-08-2009 | 08:34 PM
Full Force's Avatar
Ahhh.. and we love these money pits!!!
Old 09-08-2009 | 08:47 PM
Advantage 27's Avatar
I'm in the same club and I only realized an issue when a chunk closed the gab on the plug.
Eddie has my engine now for a rebuild and looking forward to what he can do with it.
Advantage 27 is offline
