Anyone with twins heard of swapping them in winter? >
Old 09-09-2009 | 08:19 PM
Default Anyone with twins heard of swapping them in winter?
Had a guy who builds performance boats locally tell me he swaps drives on twin motor boats every winter to make hrm last longer. Since they both spin different directions it makes the internal gears work in the opposite direction. I was told he does this because the driver that spins counter clockwise will always wear faster. Anyone else ever heard of this?or practice this? Yes I do know u must also switch the props
FuelinAround is offline
Old 09-09-2009 | 08:24 PM
Default mrfixxall
yes ive heard of this, if you think about it how often do you run your boat in reverse at full throttle,so swaping the drives would basicly be like running your drives in reverse which puts the load on the reverse gears and clutches but going forward which in sence would make your drives last longer..
FIXX is offline
Personally I can see good and bad. I would imagine there will be some gear experts here that will see this and hopefully have a good answer for you.
getrdunn is offline
Old 09-09-2009 | 08:26 PM
opinions vary on this issue i'm a marine mechanic and I say it wont hurt anything and its not a bad practice, but some people say keep port port and stbd stbd
Formula 357 is offline
Old 09-09-2009 | 10:05 PM
Vinny P's Avatar
I hate the winter!!
One thing to keep in mind is how the drives were set up. I know when I set them up, I take into consideration their rotation. If resetting used upper gears, I will set up the better gears for that drives forward rotation. Also, I may set up the forward gear lash a bit tighter than reverse. Just my way, may not be the industry standard.
Vinny P is offline
Old 09-10-2009 | 06:24 AM
Mr. Gadgets, Dick Tryce, the guru of outdrives recommended that I do this.
SkiDoc is offline
