Bravo XZ or XR???
Old 09-14-2009 | 09:21 PM
Default Bravo XZ or XR???
We are in the middle of a drive build and need to know what will handle a 9k boat with twin 575sci's. We are torn with both but long term is what we are looking for... ideas???
SonicBunny is offline
Old 09-14-2009 | 10:15 PM
xr is stronger. XZ was the first answer with hardened gears but not straight cut gears like the xr.
us1kw is offline
Old 09-15-2009 | 02:23 AM
As long as the XZ's can handle the HP, which they should be able to just fine, they will last longer. XR gears tend to wear out faster, but are needed for bigger HP.
Griff is offline
Old 09-16-2009 | 04:33 PM
With that application definitely the XR.
BDMarine is offline
Old 09-16-2009 | 07:45 PM
Well, have 8 hrs on a new set of xr's with pinion gear failure... not having the warm fuzzy feeling... lol
BTW, they were cryo'd too.... one drive gear was pitted, the primary's were fine.... both drives had same problems... merc is covering them but not sure if we want to tear down every 8 hrs...
Old 09-16-2009 | 08:04 PM
GO4BROKE's Avatar
I kind of wonder about the cryo. I've seen stock bravos last that long with more hp. Pitting is more a manufacturing issue than "usage" issue.
[img][/img]
GO4BROKE is offline
Old 09-17-2009 | 05:00 AM
right... thats what my husband thought... he's a mechanical engineer and is actually disecting one of them to have a metalurgy test done.. he has a few guys he works with that can do this... he thinks that they had a bad heat treat run...
Old 09-17-2009 | 07:53 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
How about using the new Imco SCX set up? It will work with the Bravo Transom assemblies, you just need to swap out the helmet. They are rated for quite a bit more than what your 575's should throw at them.. If they may interest you feel free to contact me.. Jamie / Lakeside Restorations
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 09-17-2009 | 09:20 AM
Sounds vaguely familliar to what I had happen a couple
of years ago , although one of my driven gears
started to chunk out too. ( they were a brand new set also)
If and when mine crap out again, I think I'm
going to try the helical type ( X/XZ)
JaayTeee is offline
Old 09-22-2009 | 10:46 AM
Any experience with the Billet marine XR uppers with there Imco billet lowers ? This is our solution for our build this winter and wondering about others experience with them.
laszlo01 is offline
