Blower Engines and plugs >
Old 09-15-2009 | 02:35 PM
Default Blower Engines and plugs
What is everyone running for plugs in there blower engines....496' 250 sc 6 lbs boost....does r41t's sound about right.....
SED70 is offline
Old 09-15-2009 | 02:45 PM
We're runnin R5673-7 496 250 SC 8lbs of B@@st
Old 09-15-2009 | 03:32 PM
Ike's Avatar
Ike
Charter Member#93
I am running NGK R5674-8 572" BDS 871 with wipple intercoolers
Gellner Engineering 1025"s
Ike is offline
Old 09-15-2009 | 05:05 PM
blue thunder's Avatar
An ngk 8 like ike runs would be equal to the ac41. The ngk#7s of runninghot are like a ac42 and a little more aggressive. As you know I run the ngk #9 because I can without fouling. Plus I don't have intercoolers.
You going out again this yr ike so I can open up a can of woop ass on you
blue thunder is offline
Old 09-15-2009 | 06:11 PM
Ngk Bcpr7es.
Back4More is offline
Old 09-15-2009 | 06:29 PM
AC R41TS or NGK UR5. They both have a slightly extended tip. If you don't want the extended tip then go with what Ike suggested.
Griff is online now
Old 09-15-2009 | 06:30 PM
Strip Poker 388's Avatar
Rob
Ive been running the 42's,for 3 years,Precision marine did pretty good bit of dynoing/tuneing with these plugs.no loading up,have good color and half way in the bridge,I use to buy all the racing plugs etc.They are are cheaperalso,I can change them about twice ayear.Ive also run the NGK R5674-8. they would load of on my old carb blower motors at 12psi,it was fat to start with.Hustler motors are efi
I run the 7's in the Chevelle street,drop down to the 8's on NOS,the 9's would load up at the track,
The Camaro are the Champions, are a 57 59's
Strip Poker 388 is offline
Old 09-15-2009 | 09:44 PM
RMPRam's Avatar
I use an NGK #R6061-9 plug in my PSI blower motors. It is a plug that PSI recommended for blower applications. Check them out. I also use an MSD #7ML-2 marine box for amplification. Never fouled a plug and they work great with anywhere from 10-16 pounds of boost.
RMPRam is offline
Old 09-15-2009 | 10:17 PM
Rob
your probably injected? and on race fuel
Old 09-16-2009 | 08:57 AM
RMPRam's Avatar
The motors made 1100hp on 92 octane fuel and use the Holley 4150 series 1000+ cfm carbs. If I intend on running it hard, I mix in some 100 LL aviation gas. 7.5 compression ratio and a really mild street roller, solid lifter cam. They have been very dependable.
RMPRam is offline
