Exhaust tip gaskets???
When I pulled my tips off last fall, there were gaskets between the flanges and the gel coat. They were destroyed when I pulled it apart. The tips sit half under water when the boat is off plane. They arent available from the manufacturer and are oblong as my tips flange is at a 45 degree angle to the tube. I think a good seal with marine grade silicone will do. Ill scuff the gel coat lightly so it can get a bite on it. Any other opinoins?
Well, not knowing any better. 2 years ago I resealed my tailpipes behind the ring with, of all things, 5200. I think my tailpipes are part of my transom now!
And I didn't just put a bead around the tips, I forced it in the hole to fill it up solid!
On the positive side, no leaks.
And I didn't just put a bead around the tips, I forced it in the hole to fill it up solid! On the positive side, no leaks.
4200 is what I use !!!
5200 is too common a name when it comes to sealant. The stuff should come with a WARNING and only be used for a permanent bond.
I have Steps & Bubbles!
Chris, how are things going?
I had marine grade silicone on those tips.
Both the old ones you now have. And the new TCMS installed
This i feel makes them sealed, clean looking, and removable.
This Cat is trying to keep up with the Big Dogs
