What’s involved going from Mark IV carb engine to a Gen VI EFI System >
What?s involved going from Mark IV carb engine to a Gen VI EFI System
Old 09-16-2009 | 06:31 AM
Default What’s involved going from Mark IV carb engine to a Gen VI EFI System
I am thinking about putting in pair of take out’s. I know an electric fuel pump will be needed along with a return line. What about wiring? Or what else I should be thinking about?
1BIGJIM is offline
Old 09-24-2009 | 12:47 PM
Anyone
1BIGJIM is offline
Old 09-24-2009 | 02:13 PM
Steve H's Avatar
artselectricinc.com
If they are complete take outs then there should be little if any wiring needed. If they are a stock set up, you will not need the return line either.
Steve H is offline
Old 09-24-2009 | 02:55 PM
bcfountain's Avatar
Registered User
Default conversion
jim,i just did the same thing on my fountain,but went from efi,to a carb.here is what i had to do.distributor,ingition box,[msd],wiring harness,fuel pump.i would say you would need a distributor,a high pressure pumpw/return to tank,and a wiring harness for that year motor.mine was a easy conversion.i went that way because of all tghe problems i had w,the vst style efi.people told me i was going to take a hit on fuel consumption,but i cannot see any diffrence.it is easy to work on for me,as i am a old school kinda guy.i am not tacking anything away from efi.there are pro,s and con.s to both.hope this helps.
bcfountain is offline
