Winterize 525's
Old 09-25-2009 | 02:11 PM
Default Winterize 525's
Just got a boat with 525's. The mechanic at the dealer showed me 2 blue plugs on each moter. They screw out amd that is supposed to winterize the boat. It does not have the pump like the others. Of course I will check the antifreeze also. Sound right?
rgv380 is offline
Old 09-25-2009 | 02:34 PM
comp's Avatar
run anti freeze thru the entire raw water side. cheap insurance
heat up the motors and make sure the thermostats let the antifreeze run thru the entire system
comp is offline
Old 09-25-2009 | 03:08 PM
obnoxus's Avatar
Charter Member #1171
they are close cooling so the motors themselves are safe,,,,, i would drain the water and run some antifreeze through anyway just to be safe with the heat exchanger,,,, cheap ins
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 09-25-2009 | 03:10 PM
GO4BROKE's Avatar
x2
[img][/img]
GO4BROKE is offline
Old 09-25-2009 | 05:16 PM
Wahoo ATV's Avatar
Racer
dont forget the blue plug on the fuel chiller and power steering cooler
Wahoo ATV is offline
Old 09-25-2009 | 10:00 PM
Check the closed cooling antifreeze to make sure its good to zero degrees
tms1155 is offline
Old 09-26-2009 | 07:09 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Exact same procedure/thought process as the 496.
Even if your engine has an air pressure system to force the water out of the engine, it's NOT good enough for FULL winterization.
Just draining the water out of a 525EFI is NOT good enough.
See this thread:
http://www.offshoreonly.com/forums/g...ing-496-a.html
Sydwayz is offline
Old 09-26-2009 | 08:02 AM
Macklin's Avatar
The tstats are on the closed cooling side, so that is not necessary. But, mine are always warm before I fill them with antifreeze anyway because I change the oil right before I fill them up. And I use the good stuff...Banfrost. Not the cheap pink stuff.
And there are alot more than two blue plugs on these motors. There are two on each header rail alone.
Macklin is offline
Old 09-26-2009 | 10:04 AM
OK - I am going to have a mechanic winterize the boat this winter to understand these engines. Just to educate myself - there are two plugs on the headers, one on fuel chiller and power steering cooler. Any others?
rgv380 is offline
Old 09-26-2009 | 10:33 AM
25 hors la loi's Avatar
yes you are right ....6 plug total
25 hors la loi is offline
