Help with New Trailer adjustment >
Old 09-25-2009 | 09:13 PM
Default Help with New Trailer adjustment
Just bought a brand new aluminum trailer for my 2000 VIP 2400 vindiactor (Baha style go fast Boat). Trying to get trailer adjusted to boat. Now for my Question. Is there any acceptable amount fot the boat to hang off the back of the bunks..At present the way it is set up there is about 4 inches hanging off. to move it foward I will have to move the winch stand about 16 inches foward to place it in front of the I beams.. Right now its all the way up behind the i beams. Then I am worried it will have too much tongue weight.
Chris
Blueabyss is offline
Old 09-25-2009 | 10:17 PM
fireboatpilot's Avatar
RIPSTA Racing Team
You want to have about 10% of the weight on the tongue. Adjust the boat to get it. Too light and it will float and sway. Too heavy and it will affect your steering but better on the heavy side. 4" overhang is fine however I like to have my bunks extend out past the transom several inches. I like the transom supported.
fireboatpilot is offline
Old 09-25-2009 | 10:28 PM
rchevelle71's Avatar
You can also raise the winch on the stand, then you wont have to move it so far forward since the stand is at an angle.
rchevelle71 is offline
Old 09-26-2009 | 07:11 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You do not want ANY hull hanging off the back of the bunks. This will translate into hull damage over time.
Sydwayz is offline
Old 09-27-2009 | 11:17 AM
Ditto, with the hull hanging off the end of the bunks you will create a reverse rocker in your hull over time. The bunks should be at least a few inches past the transom.
fossil fuel is offline
