Trying to install GPS unit?
On an 06 outlaw 25 where what are you guys useing for your power and your ground? In other words where are you picking up the power and ground from? This is for a Garmin 540s.Thanks in advance.
I would assume you could come off the hot side of your ignition wire. Then ground to the panel. I dont think I would run it all the way back to the motors. Your other option is run it back to your batteries.
