Go Back  Offshoreonly.com > Owners Forum > Sonic
aluminum trailer on 30ss >
Old 10-10-2009 | 08:55 PM
Default aluminum trailer on 30ss
I just launched my boat for the first time and the aluminum trailer floats has anyone else had this problem its a real pain in the a** the current was very stong and the trailer went under the dock. Any ideas how to fix it without putting about 500 pounds of weight on the tail of the trailer
andyt25 is offline
Old 10-10-2009 | 09:16 PM
GO4BROKE's Avatar
Steel wheels help. There is a thread somewhere about adding weight. Do a search for it. Sydwayz did it to his trailer. My 38' trailer doesn't float, it has steel wheels.
[img][/img]
GO4BROKE is offline
Old 10-11-2009 | 01:01 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It's been discussed many times on here before. The Search function is a handy tool for future use.
http://www.offshoreonly.com/forums/g...-syndrome.html
http://www.offshoreonly.com/forums/t...er-floats.html
Sydwayz is offline
Old 10-11-2009 | 08:40 PM
thanks for the info my trailer does have steel wheels ,strangest thing I've ever seen
andyt25 is offline
Old 10-12-2009 | 06:56 AM
bigboat28's Avatar
How did your boat run?
bigboat28 is offline
Old 10-12-2009 | 09:37 AM
I had two aluminum trailers - one was a float on, which you have. I sold it.....I also had an aluminum trailer (with aluminum 5 star wheels) that was a drive on. I believe it is your bunks..........call Pirate marine - he is a big aluminum trailer distributer and can probably help you convert......
kjberman is offline
Old 10-12-2009 | 08:36 PM
I burrowed a set of 21 cleaver props from a friend and the boat wouldn't hook up at all way too much wash so it'll be spring before I find out how it goes in the water. I winterized it sun and going to wrap it next weekend still need to order props.
andyt25 is offline
Old 10-13-2009 | 03:47 PM
bigboat28's Avatar
Going to be a long winter waiting to use it in the Spring but congrats.
Old 10-13-2009 | 07:04 PM
Yeah I really wanted to get to take it out but it started snowing sun so I figured it was time to winterize it
andyt25 is offline
Old 11-02-2009 | 09:13 PM
djmadmatt's Avatar
Mine Floats too but mine has the PCV Guide Pipes up the side so the trailer always stays under the Boat.
djmadmatt is offline
