pushrod length >
pushrod length
pushrod length
Old 10-25-2009 | 02:20 PM
Default pushrod length
changing my 502ho's to hp 500 carbs. i have all the stuff but am wondering if the standard pushrods will work? i found some info on BAM that the intake was 7.55 and exhaust 8.55. if this is right i cannot find pushrods in that length. anyone have any ideas thanks
prostockcat is offline
Old 10-25-2009 | 05:29 PM
Hp 500's are 8.550 and 7.550.
formula 382 sr-1 is offline
Old 10-25-2009 | 06:04 PM
where can i get sets of these?? i've checked comp and their close but not exact
Old 10-25-2009 | 06:20 PM
axapowell's Avatar
Where To
prostock
Manley push rods
8.550 - Part Number 25855-8
7.550 - Part Number 25818-8
You should get a push rod checker to be certain on these lenghts, but these part number correspond with what you are looking for!
Dave
axapowell is offline
Old 10-25-2009 | 06:23 PM
axapowell's Avatar
Where To
Hey Chris, you were looking for 1" HVH Super Suckers too!!
As for the lifters, I'm not sure what would be the replacement for the Crane 16535-16. I'm sure someone knows.
Dave
Old 10-25-2009 | 06:24 PM
This is for a Hyd Roller cam?
We use Manley and we get most of our stuff from Doug Herbert or www.dougherbert.com
I may have a used set that we took out of my Hp500 but I would have to check.
Old 10-25-2009 | 06:36 PM
thanks for the help i got morel lifters. i will double check that the 7.55 and 8.55 lengths work
Old 10-25-2009 | 06:42 PM
Also check with Competition Products www.competitionproducts.com
Old 10-25-2009 | 06:43 PM
What heads are you running?
Old 10-26-2009 | 04:59 PM
Originally Posted by axapowell
prostock
Manley push rods
Dave
The best advice given. Put those part numbers and length's up on the top shelf. As axapowell said, go to Jegs or Summit and get yourself some pushrod checkers. Do it right the first time. EVERYTHING within the valvetrain including the heads and even the head gaskets come into play.
ROTAX454 is offline
