trs leak, help !
Old 10-29-2009 | 08:52 AM
cig28's Avatar
Default trs leak, help !
guys, i have a 1975 20ft cig all original withe trs i just put full hydraulic steering on it and the wing plate attachs to the rear cap, torqued the cap to recommended spec and now i have some seepage at the top of the cap not the sides or the bottom , u can hardly see it but if u wipe it with a paper towel u get residual gear oil off of it. maybe i disturbed the gasket when i put the new studs in the rear cap for the wing plate. is it hard to change out the gasket ? is there anything i should know about taking the cap off like having to reshim anything ,can i pull the cap off, clean up the surface , put on new o ring gasket and retorque to 20lbs.
cig28 is offline
Old 10-29-2009 | 12:29 PM
Yep. Very easy just make sure the shims stay in place when you remove the cover.All you should need is the large o-ring part number 46 in the picture.Part number 25-39695. http://www.perfprotech.com/store/ass....aspx#assembly
picklenjim is offline
Old 10-29-2009 | 02:02 PM
Rookie's Avatar
TRS top cap has no shims. It will take 5 mins to replace O ring seal.
Rookie is offline
Old 10-29-2009 | 03:12 PM
He's not doing the top cap, he's doing the rear cover which does have shims under it !!
Old 10-29-2009 | 07:31 PM
Rookie's Avatar
Originally Posted by cig28
"wing plate attachs to the rear cap, torqued the cap to recommended spec and now i have some seepage at the top of the cap not the sides or the bottom"
Sorry, I thought he said top cap was leaking now, and wanted to replace that Oring.
Rookie is offline
