Can I just drop a blower on my 540's???? >
Old 10-29-2009 | 06:43 PM
Default Can I just drop a blower on my 540's????
I have 540's and was wondering if I can just drop blowers on them and be off and running?????? Here are some specs on the motors: they started as 502's then bored/stroked to 540's w/ 4.25 cranks, 9.5/1 compression w/ iron heads.......I have heuber trannys and #4's so im not really worried about blowin drives....
302Sport is offline
Old 10-29-2009 | 07:44 PM
I,m no expert by any means but 9.5 comp seems alittle high for a blower motor. probaly would change the cams also.I'm sure someone with more knowledge will chime in. good luck
tcuda499 is offline
Old 10-29-2009 | 07:53 PM
'05 Concept SF23
I would not put blowers on that combination. A hole in a piston or a cracked head are just around the corner.
f311fr1 is offline
Old 10-29-2009 | 08:02 PM
i can run thicker head gaskets to lower compression a little right????
302Sport is offline
Old 10-29-2009 | 08:10 PM
MarkSmith's Avatar
If it was a 502, I doubt that it was a bowtie block. Compression is way too high. I would forget the blower and enjoy the boat. Compression needs to be 7.5-8.0 to 1. I'll bet the internals are not strong enough to handle the blower either.
MarkSmith is offline
Old 10-29-2009 | 08:21 PM
ok i guess ill have to get all of the engine specs before i can even think about it....ive seen guys on here saying they took their 540's and put blowers on them without any further mods
302Sport is offline
Old 10-29-2009 | 08:32 PM
The compression is to high with the cast iron heads. I have put Whipples on 598's that were over 10:1, but they had alum. heads. If you ditch the cast iron heads, you could absolutely put a blower on it.
I would not just install a thicker head gasket to lower compression. You will lose your quench and that will make the engine more susceptable to detonation. There is no problem with the 502 block. What type of crank, rods and pistons? They are the biggest concern for reliability, not the block. I have made a 1000+ hp with a 502 block, so no worries there.
What blower do you have in mind? That will determine what comp. ratio would be ideal.
Eddie
Young Performance is offline
Old 10-29-2009 | 08:43 PM
thanks eddie, im really not set on running a particular blower by any means, but I am not planning on running high boost, maybe 4-5lbs.....
302Sport is offline
Old 10-29-2009 | 08:52 PM
Bosco's Avatar
check out pro-chargers marine systems tought a 40 % power increase. yes you will have to improve fuel delivery and lower compression. they shouls have all the info as they have sold piles of them.
Bosco
Bosco is offline
Old 10-29-2009 | 09:00 PM
Bosco
And most have been removed for something that works.
TxHawk is offline
