Height of a big V on a trailer >
Old 11-01-2009 | 03:44 PM
Default Height of a big V on a trailer
How tall is a 36-43' stand up style V hull on a trailer? Something like a Cig, Nortech, Apache, etc.
Trying to figure out if it would fit through the garage door. Around 9' clearance.
Thanks.
freshwaterfiend is offline
Old 11-01-2009 | 04:28 PM
t500hps's Avatar
21 and 42 footers
It would be close, but I don't think my 382 would fit under a 9ft door.
t500hps is offline
Old 11-01-2009 | 05:19 PM
I did 12X12's to be sure I wouldn't have any issues.
I think mine sits around 9', but my deck is raised higher than the boats you list. I'm closer to a BT in height.
PJDiesel is offline
Old 11-01-2009 | 05:25 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Almost all will fit through a 10' tall door. Aim for a 10' door if you can. A few will fit though a 9' door on cradling "low slung" trailers like Myco, Manning, and others. But a typical aluminum bolt together bunk trailer often with vertical 3x10 or 4x10 main bunks will raise the boat a few inches vs. aforementioned.
Sydwayz is offline
Old 11-01-2009 | 07:47 PM
seafordguy's Avatar
That's because of your big affeminent windshield.
I just measured - my Cafe is almost 8 feet exactly.
seafordguy is offline
Old 11-01-2009 | 07:54 PM
My 36' apache has the flip up windscreens rather than the racing fairing and it is on a lower slung Eagle trailer and Mine is 8' 9" on the trailer when hooked to the tow vehicle. I am building a pole barn for mine and I went with 12' doors just incase but as sydwayz said unless it is a black thunder it should fit through a 10' door.
baywatch is offline
Old 11-01-2009 | 08:11 PM
My '02 TG on a Myco will fit through a 9'door....barely
ciaoderhead is offline
Old 11-01-2009 | 08:48 PM
Thanks all. The door and garage exists already, it might be easier to build an entirely new garage in the future rather than try to put an addition on to the existing building.
Old 11-01-2009 | 09:19 PM
Strip Poker 388's Avatar
Rob
My 388 Hustler on a Myco trailer,sitting pretty level,ground to the windsheild is 8 foot 2.
Strip Poker 388 is offline
Old 11-02-2009 | 07:22 AM
BT is over 10 ft.
BDARCHER is offline
