valve covers wanted >
valve covers wanted
valve covers wanted
Old 11-04-2009 | 06:30 PM
Default valve covers wanted
looking for a set of used valve covers that will clear roller rockers and stainless marine center rise exhaust manifolds for my 454 motor
the cheaper the better, dont really care about the finish I can powdercoat them myself it they need it
so the cheaper the better im on a super tight budget
thanks for any help
pm me or email me at [email protected]
with what you got and how much
cbellamore is offline
Old 11-04-2009 | 06:41 PM
You should be able to use a stock set if you grind off those little lips on the inside.I think you only have to take off like two.That is if your using the stock heads.
WR-1 is offline
Old 11-04-2009 | 07:58 PM
fireboatpilot's Avatar
RIPSTA Racing Team
I have a set that need a new finish. They have breathers on them. Hows $100. with the breathers and $50. without, plus shipping? Their powder coated red but the it's flaking of in some spots.
fireboatpilot is offline
Old 11-05-2009 | 01:56 AM
You need to grind off the center oil drip tabs. The 500HP valve covers are the same as stock magnum valve covers and they clear. depending on what rockers you used, you may have grind off just a corner on 2 rockers. This is what Merc does.
Griff is online now
Old 11-07-2009 | 07:48 PM
fireboatpilot send me some pics to [email protected]
I tried using my stock covers theyre actually not tall enough,
they hit the poly locks on the rocker arms, and thats without tightening them down
so if anyone has any please let me know
Old 11-07-2009 | 08:55 PM
Throttle Fever's Avatar
I think Teague sells some machined poly's that you can use under stock covers.
Throttle Fever is offline
Old 11-07-2009 | 10:14 PM
RIPSTA Racing Team
I will send you pics tomorrow.
Old 11-08-2009 | 05:13 PM
RIPSTA Racing Team
Here's the pics. The one isn't too bad.
Attached Thumbnails valve covers wanted-111.jpg   valve covers wanted-ebay1.jpg
