Gen V torque specs
Old 11-06-2009 | 09:43 AM
Default Gen V torque specs
As I hunt the web I am coming up with all kinds of answers. Some up to 20lbs difference in torques. Main caps have answers are from 90 top 110lbs, rods from 50 to 70lbs, etc, etc. I need the torque spec for a Mercruiser, Gen V, 454. Rod, mains, heads, etc, etc.
Any help?
f_inscreenname is offline
Old 11-06-2009 | 12:24 PM
Rookie's Avatar
It all depends on the manufacturer of the fastener. (ie. bolt or stud) Tourque specs of a bolt is determined by the tensile elasticity of the material the fastener is made from. It is as tight as a bolt can be stretched without losing elasticity. If stretched anymore than the given specification the bolt will keep its elongation and lose clamping force.
I just used new ARP's and their recomendations.
Rookie is offline
Old 11-08-2009 | 11:43 PM
Strip Poker 388's Avatar
Rob
most iv see just use oil,and the factory manual said oil,if ya use arp and moly use there spec
Strip Poker 388 is offline
