496 ho - is this alot of hours >
Old 11-09-2009 | 10:27 AM
Default 496 ho - is this alot of hours
looking at a 2002 boat with 530 hours on 496ho is that alot?
any worries?
dieselmatt1 is offline
Old 11-09-2009 | 10:30 AM
About 75 hours a year, thats probably normal, especially if in FL.
TampaBeach is offline
Old 11-09-2009 | 10:31 AM
Smitty's Avatar
That is certainly a high number. Any way you can hook up a scanner and see where it has spent most of its running time?? If it is all mostly idle time, then no worries. If it is mostly 3500 and above I would be concerned.
Also give us more info on brand and model of the boat it is in.
Smitty is offline
Old 11-09-2009 | 10:46 AM
2002 baja 25 outlaw
Old 11-09-2009 | 11:05 AM
Dave M's Avatar
Veteran: Navy
Like Smitty said, get it scanned. When I scan my motor, it shows below 1500 rpms for 50% of the hours.
Dave M is offline
Old 11-09-2009 | 11:37 AM
530 hours on an 8 year old boat is only 66.25 hours a year, very average for the age.
Is this a repo deal or does the seller have every book, service record since day one? If it is stock, with frequent fluid changes/service and reasonable scan history (not all WFO) then is it getting to the point of some maintenance but not a case of run away.....
Jupiter Sunsation is offline
Old 11-09-2009 | 11:55 AM
was a repo no records, looks brand new. outdrive looks like brand new.?
Old 11-09-2009 | 01:19 PM
yesrej's Avatar
i have 350 houres on my 2002 25 outlaw. runs like it was brand new. i dont think 520 hours is a big deal as long as it has been mantained.
yesrej is offline
Old 11-09-2009 | 01:31 PM
Maybe for IL, not for FL. If it has that many hours and looks like new I would be willing to take a chance the previous owner took good care of it. But as stated scan the motor, it is possible on some baja's the hour meter is hooked up to ignition and not actually running time, so if the key is just turned the meter is moving, even if the motor is off.
Old 11-09-2009 | 03:18 PM
bajarick's Avatar
Default Hrs
any worries?
I have a 33 outlaw has 640 hrs and
never had a problem with twin 496 mags,
its all in the maintenance !
By the way its for sale on oso classified
baja add 15. Turn key boat, not a cleaner
03 around.
bajarick is offline
