500 EFI cam in carb engine >
Old 11-17-2009 | 06:15 AM
Default 500 EFI cam in carb engine
have a 9.5 to 1 509 going to a dart intake & 850, have full headers, can I use a 500 H/P EFI cam with this set-up ? thanks Rob
ezstriper is offline
Old 11-17-2009 | 06:44 AM
yes
mike tkach is offline
Old 11-17-2009 | 12:44 PM
Sure, it should work fine.
Griff is offline
Old 11-17-2009 | 02:55 PM
baja36ft's Avatar
i would use the 525 efi cam....
baja36ft is offline
Old 11-17-2009 | 05:58 PM
ok, any body have one ? Thanks rob
Old 11-18-2009 | 01:52 AM
525efi cam is a Crane 741 on a 114 lobe sep. Crane has limited cams available now so you would probably be better off to have rmbuilder custom grind one.
Griff is offline
