500 hp engines and drives >
Old 11-23-2009 | 09:04 PM
ktm2212's Avatar
Default 500 hp engines and drives
I have a pair of Merc 500hp carb motors. GEN VI. Totally fresh with less than ten hours since rebuild. 550hp with stock carbs. I have dyno sheets. Compression and cam bumped up a bit but good for pump gas. 99 Model year
Engines and cmi sport tubes $25k.
Also have pair of bravo I drives. 1.35 gear ratio. Gone thru last winter. New clutch cones. $5k for the set.
My boat sustained hull damage so had to part out.
All reasonable offers considered but still looking for hull so may not be on market for long.
ktm2212 is offline
Old 11-23-2009 | 09:31 PM
OUTLAW11's Avatar
Default Fountain
GOOD LUCk?????
OUTLAW11 is offline
Old 11-24-2009 | 05:42 AM
c_deezy's Avatar
This the Fountain that ended up on the road in Dayton a couple months back?
c_deezy is offline
Old 11-24-2009 | 06:52 AM
Originally Posted by OUTLAW11
GOOD LUCk?????
What does that mean??????
kreed is offline
Old 11-24-2009 | 08:17 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
GOOD LUCk?????
Price may be high but what was purpose of the BS flag?
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 11-24-2009 | 10:58 AM
ktm2212's Avatar
Yes...same fountain. Everything from engine compartment on back is fine. I have to fix the skags on the drives but otherwise everthing is in great shape. Didn't understand BS flag either. If you don't like the price....don't buy it. I am open to all offers.
ktm2212 is offline
Old 11-24-2009 | 04:53 PM
maybe you should sell it to the fountainkid , since he is fixing the boat back . that is going to be a big job. if anybody is thinking about buying the motors they are nice and sound very good as I was parked next to it at the cinci poker run this past summer .
tim brown is offline
Old 11-24-2009 | 06:26 PM
How did it end up on the road?
tx911 is offline
Old 11-25-2009 | 08:01 AM
ktm2212's Avatar
Him and his dad have some big motors sitting there ready to go in when hull work is done. I agree a big job. I know nothing about that type of work but have some say can't be done...some say could be done. We'll see I guess. I know the X dimension on that boat was set up really high from fountain (factory installed extension boxes) so he may need my boxes (or someone elses) to make it work. I hear he's pretty talented so I'm sure he has a plan.
ktm2212 is offline
