need information on 2001 Ford F350 7.3 powerstroke >
Old 11-27-2009 | 05:23 PM
Default need information on 2001 Ford F350 7.3 powerstroke
I am considering purchasing a 2001 F350 crew cab dually 87,000 mi 5 speed 4WD to tow my 30 foot boat and would like to know pros and cons.
GERRYM454 is offline
Old 11-27-2009 | 05:30 PM
the 7.3 is one of the best diesels ever made...if you do anything first id put an ATS ported intake housing on the turbo($425)...the turbos in that year and 02 had problems with surging under loads, that would eventually blow the turbo up. then a good clutch, and depending on if you want higher HP depends on what else youd need done.
Other then that id say thats a pretty reliable set up..i had an 02 f250 4x4 with an auto..had over 200k on it when i sold it and ran like a top.
boatntrkr is offline
Old 11-27-2009 | 05:33 PM
jfm
I have an 02 single wheel 5 speed and love it. Knock on wood the only thing wrong has been the HPOP lines. The clutch is crap and I would recommend an upgrade. The pressure plate is known to let go. I did a complete banks kit with the six gun and it tows like an animal. JMO
jfm is offline
Old 11-27-2009 | 06:01 PM
Default 7.3l
It's a great powertrain. It's probably a ZF 6-speed though? Only the gas engine SD's could be bought with the 5-speed.
That truck may have the dual mass flywheel, which starts to rattle off the line when they wear. Most guys replace to a single mass flywheel when they swap the clutch out. Idle away in 1st and listen for a rattle that goes away at about 800 rpm.
Randy
bustedbrick is offline
Old 11-27-2009 | 06:29 PM
seafordguy's Avatar
Randy
Agreed - I didn't know that you could get the 5 speed on the 7.3. I have a 2000 6-speed dually F350. 99k miles. I LOVE it. We drive it everywhere. I use it to commute, and my wife and I take it on trips when we go.
About 6 months ago I was sitting at Shell filling up and this guy pulled up beside me with a SRW that was a 2000. We got to talking and I asked him how many miles he had on it. He replied he only had 386k on that one but on his other one he had over 400k. I asked him what all he had done and he replied he had never done anything other than replace oil, tires, brakes, and fuel filters on EITHER one....
Check Diesel Garage.com - those are good trucks!!
seafordguy is offline
Old 11-27-2009 | 07:56 PM
jfm
I will clarify my 5 speed comment. It is a 6 speed but 1st is so low it is worthless so I call it a 5. So yes the correct term is 6 speed.
jfm is offline
Old 11-27-2009 | 08:07 PM
South Bend Clutch;
http://www.southbendclutch.com/ford_catalog.html
Catmando is offline
Old 11-27-2009 | 10:08 PM
It's a great gear to get a heavy boat moving. The ZF is a really strong and reliable trans, I rarely hear of any problems with them.
Mine is a daily driver, same kind of use as seaford. 22.7 mpg at 70mph unloaded, 17 in town, 11 towing the resin rocket on a steel Myco.
Good luck, R
Old 11-27-2009 | 11:26 PM
fireboatpilot's Avatar
RIPSTA Racing Team
I have an 01, 7.3, Crew cab dually, automatic. I've added a Banks turbo, Big head waste gate, Banks turbo wheel, exhaust elbow, 4" exhaust and HyperTech 3 stage kit. It's a beast. I do keep an eye and go easy on the overdrive when towing. They shouold have went with the Allison trans but so far, 158000, no trans problems. It's a great truck. The only constant problem I have had with the truck is that the front hubs wear out prematurely and cause tires to wear and slight shimmy. This is anoying and I wish someone had a solution to this. I've replaced them 5 times so far since 2004. Other than that, go for it.
fireboatpilot is offline
Old 11-28-2009 | 12:14 AM
Have you checked the Ford diesel forums for those hubs? They might know of a solution.
Catmando is offline
