Rocker Damage
Old 11-30-2009 | 01:16 PM
Default Rocker Damage
540 BBC Hyd rol cam.. #7 Intake Rocker seems to be damaged right where the Lockdown nut is.. Looks like the nut & rocker were scraping??? weird.. Just adjusted the valves about 2 months ago.. Did not notice it then.. Only difference this time went a tab tighter on the valves.. closer to 3/4 then 1/2 turn. did not notice anything out of the ordinary running wise.. no new noises.. ( i will post pic tonight when I can)..
Any ideas why the nut and rocker would meet? Other then I tightened it down a tad to tight.. Perhaps bad lifer? Spring??
JohnSchiavarelli is offline
Old 11-30-2009 | 03:53 PM
tomtbone1993's Avatar
rocker upside down?
tomtbone1993 is offline
Old 11-30-2009 | 07:55 PM
johnnyboatman's Avatar
maybe the stud backed out?
johnnyboatman is offline
Old 11-30-2009 | 08:16 PM
Needles left the fucrum?
AO31 is offline
Old 11-30-2009 | 08:23 PM
bobbowobbo's Avatar
pic?
bobbowobbo is offline
Old 11-30-2009 | 08:45 PM
Thunderstruck's Avatar
Scratched the rocker with the wrench?
Long time cult member.
Thunderstruck is offline
Old 12-01-2009 | 07:02 AM
That last comment was a good one.. I will have to post a pic tonight.. The stud backing out sounds logical I assume..
I also assume a weak/broken spring as well as a worn cam lobe as well as a weak/broken lifter "could" result in this?? I would tend to think with any of the above scenarios, I would have noticed something running "weird"..
Old 12-01-2009 | 12:14 PM
mikes280's Avatar
how big is the cam is there a chance the stud is rocking or flexing
mikes280 is offline
Old 12-02-2009 | 03:31 PM
Mike
have to check and take a pic tomorrow.. rain is crazy today..
I don’t think anything has flexed or changed.. I think it (more than likely) has something to do with my last valve adjustment.
One weird thing though.. The #7 plug was a little darker than the rest.. not much.. but noticeable.. all the other plugs looked perfect.
Perhaps a leak down test is in order?? I did a compression test back 2 months ago(when I did the valves). Each cyl was 150+- a few.. Looked good.
Old 12-08-2009 | 08:13 AM
Some general shots of the valve train
Attached Thumbnails Rocker Damage-rocker2.jpg   Rocker Damage-rocker3.jpg   Rocker Damage-rocker6.jpg
