trailer bow stop help
Old 12-04-2009 | 09:22 AM
Red face trailer bow stop help
I have a 35 fountain on a manning trailer.which position should the v stop be under the bow eye under the bow eye or as low as i can make it?
sonic28 is offline
Old 12-07-2009 | 09:34 PM
The bow eye of the boat should be just under the V. The reasoning is that the cable or strap which is on the winch will pull the boat straight - not up or down which would put un - needed stress on the trailer as well as the boat. The second reason is in case of a panic stop the bow eye will push against the v or roller and be stopped.If the boy eye was on the top the trailer V the boat could push forard and cause damage to the boat and trailer.
Neil
snogiyogi is offline
Old 12-08-2009 | 08:32 AM
seafordguy's Avatar
Also - When I got my trailer it was below the Eye, and on steep ramps it will get caught on the stop and you will have a nightmare getting the boat off.
seafordguy is offline
Old 12-08-2009 | 08:54 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If you have a roller the bow eye should go below the roller.
If you have a split front V configuration for your bow stop, it does not matter.
When you have a Fountain, you have to make concessions for the beak. You want your bow stop to be a bit on the low side, so no matter what angle ramp you are using, the bow/beak gets caught and lifted above the winch/stand.
Just FYI for others, most Mannings and Mycos have a split V-bunk for the bow stop, and the winch stand is a whole separate unit. Take a look at the boats in the classifieds for examples.
In an emergency situation, a bow eye sitting below a roller is not going to offer much "stopping power." Stopping power is going to come from having a ratchet strap angled toward the aft of the boat; as well as your transom straps.
Sydwayz is offline
Old 12-09-2009 | 11:40 AM
DM
Check out www.teamshogren.com and you will see many examples.
DM is offline
Old 12-09-2009 | 01:02 PM
thanks to all the pic shows it all
sonic28 is offline
