Go Back  Offshoreonly.com > Owners Forum > American Offshore
HP/speed question on a 31 AO >
Old 12-04-2009 | 01:58 PM
tssteph's Avatar
Default HP/speed question on a 31 AO
I am wondering what the speed difference would be if you went from 115 mph at 5200 with 690HP@5200 to 850 hp at 6000. Will 160 hp pick up 800 rpm with the same ratio/prop/weight setup? Using the prop slip calculator with the current slip etc it says 131 is this really feasible?
tssteph is offline
Old 12-04-2009 | 10:06 PM
Ohhh Boy! Whatcha got up your sleeve? I'd imagine Quest would have some insight.
AO31 is offline
Old 12-05-2009 | 07:58 AM
What drives are you running...
bobkatz is offline
Old 12-07-2009 | 08:42 AM
tssteph's Avatar
Nothing, I swear.....
tssteph is offline
Old 12-07-2009 | 08:44 AM
tssteph's Avatar
ones that 850 hp would probably break.
It might last a while since I am easy on it
tssteph is offline
Old 12-08-2009 | 05:57 PM
Smile
Leave it alone i may need a ride need summer.
tman is offline
Old 12-09-2009 | 08:40 AM
tssteph's Avatar
one more ride and you will be converted to a cat.
tssteph is offline
Old 12-09-2009 | 10:00 AM
Ran-Dom 32's Avatar
I seen a cool pic. of your boat in the Nov. issue of performance boating magazine, actually the boat on the cover has very similar graphics to your 31
Ran-Dom 32 is offline
Old 12-09-2009 | 03:39 PM
tssteph's Avatar
yep I got the issue. It is a pic of me putting it on the Pier 57 boat. (i hope he reads this)
Attached Thumbnails HP/speed question on a 31 AO-img_8893.jpg
tssteph is offline
Old 12-09-2009 | 11:07 PM
Now reality is back where it should be; the cat is out in front of the V.
Catmando is offline
