What oil pan to use? >
Old 12-04-2009 | 01:58 PM
Dock Holiday's Avatar
Charter Member #34
Default What oil pan to use?
What brand oil pans do you guys like to use?
I'm looking for recommendation for marine application, 540 CI with Dart block.
Thank you
Dock Holiday is offline
Old 12-04-2009 | 02:05 PM
Smitty's Avatar
I assume you have 1 piece RR. main seal.
Here is what I used on my 540's
http://www.cantonracingproducts.com/...ion&key=18-362
I also installed these so no more dry starts:
http://www.cantonracingproducts.com/...ion&key=24-016
Smitty
Smitty is offline
Old 12-04-2009 | 02:28 PM
cougarman's Avatar
Thank you
I have a few of the Keith Eickert cast aluminum pans.
New they were over a grand each. think you can get them around $700 each now.
If you like I will let two of them go for $400 each.
They are either 12 or 14 quart,.......can't remember off hand.
Jon
cougarman is offline
Old 12-04-2009 | 02:36 PM
Charter Member #34
Smitty
Smitty,
Dart uses the 2pc rear main seal.
Mark
Old 12-04-2009 | 02:45 PM
Smitty's Avatar
Mark
Canton also makes pans for the 2 piece rr main seal. They have all kinds of pans.
Are you looking for steel or aluminum. I went with steel to save $$$$$.
Dave
Smitty is offline
Old 12-04-2009 | 02:51 PM
I use the Canton 18-364 - BBC REAR SUMP MARINE POWER PAN (18-364)
A little more money but it a nice pan.
Kris Vogt
kvogt is offline
Old 12-04-2009 | 03:04 PM
Charter Member #34
Jon
Jon,
I am interested in those. Do you have any pictures or other information on them?
Mark
Old 12-04-2009 | 03:30 PM
GPM
GPM is offline
Old 12-04-2009 | 04:24 PM
Smitty's Avatar
Mark
Make sure you will have enough clearance under those KE pans. The stringers in our boats are close to the bottom of the motors.
Smitty
Smitty is offline
Old 12-04-2009 | 04:29 PM
Canton here
whoya is offline
