Block Freezing ?
It has been 34* for most of the day and will be in the 20's overnite and 24 By morning.
I pulled the hoses and opened the drains but one side just trickles out . I stuck a wire in and tried to open it up but nothing but a trickle. I let it drain all night but am a little worried with this weather. Do I have anything to worry about or should I just drop a work light in the bilge overnite?
chuckbeecher
From: Anywhere from the Laguna Madre to JAX and beyond
Put a couple of droplights in the bilge with a coupel of 75 watt bulbs or just one with 100 watt or buy a small ceramic heater and set it at 70*. I have done all of the above with boats sitting outside in the driveway and also hanging in a slip. Never drained them and never a problem.
4 hours at 29* can ruin alot .
If there is water in your fresh water tank you may want another heat source in the cabin/cockpit area.
Remove the drains fittings from the block then use a small mini screwdrive "not wire" to loose in the sand or rust up in the block if you can't fill the engine with antifreeze is it in doors or outside? and drain the exhaust manifolds too.
I think I am just going to pour some Antifreeze in thru the Tstat and put a drop light in. I snapped the cranck on my last trip out thats why I have to pour it in.And its outside.
You should be able to use a wrench 9/16 is it a stock cooler? pour it in the engine water pump hose that go's from the t stat to the inlet of the engine pump pour it in the hose that might mix better then shake the boat back and fourth at the rear side of the boat to try to mix it better.
Charter Member #139 /Moderator/Platinum Member
Go to home depot and get one of the oil filled electric radiators plug it in and no worries
Kept the Bullet and the condo and joined the cig 20 restoration club.
