props
Old 12-07-2009 | 08:38 PM
Default props
has any one heard if you can by a 22 pitch 3 blade props for my 29 scarab i can only get 4700 rpm with my mirage plus 23 pitch tried 21 4 blade but lost to much at top end but gained crazy torque up to 3800 rpm
humpster is offline
Old 12-08-2009 | 12:06 PM
You need to move to a standard mirage 23P. You should pick up at least 200 rpm because of the cupping the mirage plus has. I believe it would have the same effect as moving down to a 22p.
86scarabIII is offline
Old 12-08-2009 | 07:09 PM
Rookie's Avatar
What engine are you running? Where is max HP on the engine. If it is an engine thats peak HP is between 4600-4800 you're already there.
A mirage and a mirage plus are 2 different props. The plus has more cupping than a standard mirage, but I also think the rake is different. It is not just a change the prop and you gain RPM's. You might lose some handling characteristics, have planing issues and still not gain any speed. If you like the characteristics of the Plus than just have the blades thinned (labbed) and build your current prop to work great for you boat. You could also get your prop repitched to 22". But the labbing would be the best bang for the buck.
I have 25 mirages and needed to add the cupping so I could get on plane easier. I also had the blades labbed so I could get my RPM's back that the added cupping took away. I also gained a lot better handling characteristics at speed with the added cupping.
Rookie is offline
Old 12-09-2009 | 05:51 AM
i have 350 mag mpi they say 5000 rpm is the # have new 23 plus props if labbing will solve the problem that i would do. also my tabs have a spacer in them i m told and they don't go up past paralell to the bottom of the boat could that have something to do with rpm
humpster is offline
Old 12-09-2009 | 02:16 PM
scarabman's Avatar
The spacer is there to keep the boat running "wetter". The bottom of the boat also has a wedge built into at the outer strake. If you are feeling ambitious, and a little daring, you can grind that out and it will help free up the bottom of the boat also.
I used to run labbed 23s on mine when I had it. It only gained about 1-2 mph as I recall though.
scarabman is offline
Old 12-13-2009 | 05:40 PM
thanks guys where is the best place to get your props labbed any input would be good thanks
humpster is offline
Old 12-27-2009 | 08:28 PM
On Time's Avatar
BBlades
On Time is offline
